Guages with the Comptech?
Just this one:
A boost gauge is nice but keep in mind that most are calibrated for 25-30 psi. As you're only running 5 the needle will hardly move. Just make sure it's one that shows vacuum.
Other gauges like oil temp and pressure would be nice if you track of drive hard.
A.) AEM Air-Fuel Wideband - to make sure you don't blow up the engine from being too rich or lean
and either
B.) Defi BF Boost - to make sure the SC belts or vacuum line don't loosen and I lose boost (belt) over time or worse (vacuum)
C.) Defi Oil Pressure - to make sure no leaks develop
My SOS pillar Pod only had room for 2 so I chose A & B.
Links to gauges below in my sig.
and either
Nhan
Jun 14, 2006 07:15 PM
