has anyone used a supra fuel pump?
Old Aug 18, 2008 | 12:23 PM
GDM S2K's Avatar
the noise it makes is over rated.....
if were thinking like that sump the tank and go with a A1000 aeromotive, after spending 200 whats another 300?
Old Aug 18, 2008 | 12:34 PM
jzz30's Avatar
ok i would but if it still whines like a walbro then its out of the question.
Old Aug 18, 2008 | 01:11 PM
2big4aS2000's Avatar
only time you hear the wine is when the ignition is on and the car is not running. over the engine & exhaust at idle you should not hear it. Driving down the road with the add road noise you really shoud not hear it.
you could always insulate the above the fule tank to try cut down the noise.
I like to hear the pump prime, wait till it stops b4 hitting the start button.
Old Aug 18, 2008 | 02:18 PM
Chris@NLM's Avatar
Use the evo 9 pump, you can get them used for like $30 and it flows more.
Old Aug 18, 2008 | 03:53 PM
jzz30's Avatar
im not an evo 9 pump! besides i dont want a used pump
saving $150 for a $4000 engine isnt really all that smart.
as for the noise, when i turn the key on is when i really dont want to hear the pump
Old Aug 19, 2008 | 07:48 PM
deathsled's Avatar
supra pump can support 750hp, its a pretty ridiculous factory pump
a good fit for 3000GTs
Old Aug 19, 2008 | 09:24 PM
jzz30's Avatar
im thinking the supra pump wont fit without some major mods. the oem and walbro pumps are both about the same size and they fit inside a cylinder that houses the pump. the supra pump is much larger in diameter so i think it wont fit unless i cut out the cylindrical housing.
samsam
Apr 4, 2019 08:43 AM
Dize
Apr 10, 2014 06:25 AM
Forcedbird
Aug 30, 2013 06:05 AM
Irishflame27
Aug 7, 2009 09:05 PM
