Head gasket for turbo
Originally Posted by dsddcd,Sep 16 2010, 12:15 PM
Your crazy you still have room to go with your car, you should get back on the dyno and turn the boost up, if I recal corretly you were only at 20PSI.
I'm only at 20psi, but I don't want to get too far ahead of myself. Right now, I just want it to be decently quick and reliable.
thank you for all your advise and information guys. so dsddcd, you think i should just go with stock head gasket for turbo charging my s2k? im planning to only boost 10 lbs with stock internals, walbro fuel pump, hondata flash pro with 650cc injectors on 91 octane pump gas.
mahle pistons. i still havnt blown my hg, still on my first one with arp studs, but if i could do it again i would hone the block to 87.25 and use the mahle low comp frm friendly pistons, if my hg blows ill be doing this also
