Headgasket choice with 89mm bore
Old May 29, 2007 | 06:01 AM
Sideways's Avatar
Default Headgasket choice with 89mm bore
There has been lots of discusions on headgaskets to lower compression. My question has to do with with a factory thickness headgasket that would not lower the compression.
Is anyone aware of a factory thickness gasket that will work with 89mm bore and ARP studs. Those of you running built engines, what are you running?
Old May 29, 2007 | 07:06 AM
John_Z's Avatar
I believe Cometic makes an 89mm gasket in .030 thickness which is closest to stock. They even have a .027 thickness version. Not sure if they work with ARP headstuds though.
Old May 29, 2007 | 08:06 AM
bigpurp's Avatar
OEM HG here.
Old May 29, 2007 | 05:11 PM
Elite Performance's Avatar
yes cometic does sell a 89 ml with 030 thickness thats what im running on my car and i also have the arp studs you are good to go
but whne you send out the block to be worked on give them your new head gasket your new piston and yoru new sleeves and they willmake everythign fit perfect thats what i did to mine i waited for all the parts and matched everythign perfect
Old May 29, 2007 | 05:17 PM
ideugene's Avatar
I have the cometic 89mm as well!
cujet
Jan 31, 2016 01:42 PM
TRBOKEV
Dec 21, 2010 02:22 PM
EK9MAX
Apr 16, 2009 11:14 AM
WhiteAP1
Jun 22, 2007 11:24 PM
GDM S2K
Oct 15, 2005 09:38 AM
