Headgasket Question
Old Apr 6, 2009 | 04:52 PM
jdnissanz's Avatar
Default Headgasket Question
What headgasket options do we have other than the stock headgasket? Are there more durable headgaskets? Also, is anyone with a built motor using any other headgasket other than OEM?
James D.
Old Apr 6, 2009 | 05:05 PM
jdnissanz's Avatar
After searching for a while some people use a copper spray and apparently it works, but IDK if that will help my issue!
Aftermarket headgaskets at least Cometic doesn't seem reliable, man am I confused.
James D.
Old Apr 6, 2009 | 06:38 PM
dsddcd's Avatar
James D.
I have always used copper gaskets with KW Copper coat
Old Apr 7, 2009 | 09:38 AM
jdnissanz's Avatar
Do people with built motors recommend any other brand headgaskets?
Old Apr 7, 2009 | 09:57 AM
AndyFloyd's Avatar
if kutsujula can make 701whp on a stock F20 do you think OEM isnt durable enough?....think about it....
Old Apr 7, 2009 | 04:57 PM
jdnissanz's Avatar
I understand people like Kutsujula are making it on the OEM headgasket, but I am running less boost and my set-up is not inferior in any way. So my question was what can I do to prevent it if I go with the OEM headgasket again??
James D.
Old Apr 7, 2009 | 05:17 PM
Revenge's Avatar
He has a much better mani than us log guys. I have pretty much made up my mind to go 3mm ILP. I need reliabity since I am not too good at turning wrenches.
dagle's Avatar
what's wrong with the headgasket? if it blows, change it out.. its not that huge of an issue unless if you let it become one.
wochi
Oct 15, 2015 09:05 AM
SilverStreak476
Jul 2, 2012 12:29 PM
buzz944
Jun 21, 2012 02:35 PM
ChefJ
Feb 16, 2010 01:38 PM
Matty_Vr6
Feb 10, 2010 08:19 PM
