headgaskets for 89mm block
Old Oct 18, 2010 | 02:44 PM
fadiss2k's Avatar
Default headgaskets for 89mm block
Ok, i have a f20c sleeved block. It has 89mm bore and i was wondering what headgasket would be best if i am aiming to hit 750-800 whp? i usually always use OEM stuff, but i heard a few stories saying with an 89mm bore, the thickness between the walls is thin and the oem and cometic hg blow. I was looking at the cosworth, but they only come in 88 or 90mm. the rep at cosworth said it would be ok to use a 90mm on an 89mm block. So my questions are:
1. Is the cosworth gasket a good option for my setup?
2. Is it really ok to use a smaller diameter hg than what the bore is on the block?
I know a bigger smaller bore gasket would create a hot spot and is a definite no no.
Thanks in advance.
Fadi
Old Oct 18, 2010 | 02:48 PM
bois2k's Avatar
i went with the cosworth for my 88mm bore so hopefully its a good hg.. but the 90mm should b just fine
Old Oct 18, 2010 | 02:49 PM
AusS2000's Avatar
Have a look at SCE gaskets. Not sure what bore sizes they do standard but pretty sure they can fab a custom headgasket and their o-ring sealing is fantastic.
Old Oct 18, 2010 | 02:54 PM
AusS2000's Avatar
If Golden Eagle have it how is it OEM?
Old Oct 18, 2010 | 02:58 PM
AusS2000's Avatar
Ahh, got ya.
Old Oct 18, 2010 | 04:12 PM
teamvalorracing's Avatar
call cometic. they have 89mm f20/22 gaskets in stock for like 113 shipped. great oem thickness gaskets for a small over bore.
02_s2k
Jul 19, 2014 11:26 AM
exodusx7x
21
Dec 6, 2010 01:31 PM
aznoophi
Mar 23, 2010 10:42 PM
konerri
Aug 27, 2009 04:09 PM
s2kpnoy
Sep 26, 2007 12:58 PM
