Heat issue, running AC.
Old Aug 11, 2011 | 10:55 AM
vader1's Avatar
Default Heat issue, running AC.
Just have this minor issue that only happens when my car is heat soaked, it is a super hot and humid day and I run the AC. I will punch it and the car will buck a little bit under boost, don't know what is actually occuring but thought the car might be rapidly pulling timing because of minor knock or something. If I turn the AC off and punch it, it is just fine. Car is low miles, plugs are fine, coils are new. Everything is in good shape, about 8 pounds of peak boost from the SC and the air to water intercooler is working as it should.
My question is what (besides a little drag from the compressor) is different when the AC is running that would cause this? I run a Emanage so I presume it is something the stock computer is seeing and making an adjustment, but what does the stock computer see differently when the AC is on?
On a side note, it is possible that I have air in the head after chagning the intake manifold gasket, and am do to do a drain and fill of the whole system shortly.
Thanks for any insight.
Old Aug 11, 2011 | 02:19 PM
camuman's Avatar
The tune adds fuel and rpm when the compressor is on if I remember right. Check in te emu software if there is controls for the ac. When I get home I'll check in aem cause I know there is stiff for it in there. I bet the car is flooding or leaning out for a sec and possibly knocking.
Old Aug 12, 2011 | 06:39 AM
vader1's Avatar
I do believe the AFR guage reads very fairly rich when this happens. High 10's.
Old Aug 12, 2011 | 07:17 AM
DBXFX's Avatar
possibly adjust the AC load comp in the aem software. I believe its under the fuel or setup tab
vader1
Jun 5, 2014 07:39 AM
Drabowski
Oct 13, 2012 08:42 PM
21k
Sep 25, 2009 04:31 PM
JoeyBalls
Oct 13, 2008 10:52 AM
Amit
Jun 20, 2006 02:07 PM
