heat shield for turbo...
Old Oct 1, 2007 | 09:36 AM
ShMooveS2k's Avatar
Default heat shield for turbo...
Im using the P-fab manifold and a GT3076R turbo, my manifold and wastegate and downpipe are wrappeds my turbo is bare. The problems i have is the heat from my hotside melted the front of my fusebox after we moved the box 90degrees i know people can get their stuff HPC coated but how much does that help? should i use a turbo blanket or like some certian type of heatshield if so were can i get one any suggestions? thanks
Old Oct 1, 2007 | 09:38 AM
s2khondas's Avatar
i have the same setup, did u take the powersteering box off where it was mounted and moved the fusebox closer to the fender?
Old Oct 1, 2007 | 09:53 AM
ShMooveS2k's Avatar
we moved the battery to the trunk and turned the fuse box 90degrees (longways)
Old Oct 1, 2007 | 11:54 AM
Hasid Lafre's Avatar
I wold have the manafold jethot coated and if you can find someone have it ceramic coated also.
Seen a twin turbo 3.8mustang whoes hot pipes were jethot coated inside.out and ceramic coated outside.
5 min after he shut down you could touch the pipes and not burn yourself.
Man I would kill for that car of his.
Old Oct 1, 2007 | 12:23 PM
ShMooveS2k's Avatar
how long would the down time be to get this done if i turn everything all at once.
ShMooveS2k's Avatar
so im gettin that turbo housing covers dont work?
Old Oct 2, 2007 | 05:46 AM
s2guru's Avatar
sure they work.
i have all my stuff HPC and bought a good turbo blanket too..
caughtbycops
Forced Induction For Sale
Apr 2, 2011 08:20 PM
Boostaholic
Oct 19, 2010 05:05 PM
s2guru
Sep 27, 2007 07:27 PM
s2guru
May 10, 2007 06:53 AM
