help with CTSC
Old Jan 26, 2009 | 04:55 PM
SRR's Avatar
SRR
Default help with CTSC
during full throttle it feels like the bypass valve is opening, it pulls way harder at 1/4 throttle...
i have all the vacuum lines connected.. i am new to superchargers n i cant figure this out
any ideas?
Old Jan 26, 2009 | 05:05 PM
s2k aok's Avatar
dump the bypass valve for a blow off valve.
Old Jan 26, 2009 | 05:17 PM
SRR's Avatar
SRR
i plan to...lol do u think thats what is causing it? has this ever happened to anyone else?
Old Jan 26, 2009 | 06:24 PM
SIIK2NR's Avatar
Need more info.
New/Used kit?
Who installed it?
How does it "Feel" when the bypass opens?
Old Jan 26, 2009 | 06:26 PM
SRR's Avatar
SRR
its a used kit... i installed it,
once i floor it it feels like the bybass valve opens n it falls flat, but if i go half or 1/4 throttle it feels better
Old Jan 26, 2009 | 07:42 PM
SIIK2NR's Avatar
You say the bpv opens.... can you "hear" it open? You shouldn't hear anything, it feeds back into your intake.
AC or non-AC?
Old Jan 26, 2009 | 07:45 PM
CKit's Avatar
Did you hook up the "black box" ESM?
Old Jan 26, 2009 | 07:59 PM
SIIK2NR's Avatar
Was it running normal....and NOW it does this? Or is this been the problem since you installed it.
answer the question on the ESM. Could be a wiring issue or disconnected wire.
Old Jan 27, 2009 | 11:51 AM
SRR's Avatar
SRR
i havent hooked up the esm yet.... could this be it?
Old Jan 27, 2009 | 11:54 AM
SRR's Avatar
SRR
[quote name='SIIK2NR' date='Jan 26 2009, 08:42 PM'] You say the bpv opens.... can you "hear" it open?
