help with CTSC
Old Jan 27, 2009 | 11:56 AM
SRR's Avatar
SRR
ill try to install the esm now n see... but could this really be causing this problem
Old Jan 27, 2009 | 12:08 PM
TRBOKEV's Avatar
It is DEFINITELY the ESM. That hides boost from the stock ecu.
Make sure to solder all connections also.
Old Jan 27, 2009 | 01:46 PM
SIIK2NR's Avatar
Originally Posted by SRR' date='Jan 27 2009, 12:51 PM
i havent hooked up the esm yet.... could this be it?
Old Jan 27, 2009 | 02:07 PM
SRR's Avatar
SRR
thanks guys... like i said i am new to superchargers, i have experience with turbos n it would still boost without such device
car feels good... wow ne ways back out for more driving
Old Jan 27, 2009 | 03:34 PM
nightcrawler7188's Avatar
anyway congrats on solving the problem. don't get used to all solutions being this simple
Old Jan 28, 2009 | 09:38 AM
dragtek's Avatar
make sure u dont rush connecting those wires, take your time or it will lead to the same problem again
Old Jan 28, 2009 | 11:29 AM
s2000Junky's Avatar
Yep, thats a tight confining area to work in with soldering your wires, I had to do twice, one of my wires was not a good connection so take your time and do a good job.
Old Jan 28, 2009 | 12:31 PM
DeadZero's Avatar
wow. i'm amazed something didn't blow. Especially with you going Full-throttle and not knowing whats wrong with the car.
Old Jan 28, 2009 | 12:40 PM
s2000Junky's Avatar
I know i was thinking holy cow he didnt put in the esm and is flooring it Crazy! I guess either he got lucky or maybe thats all that will happen, no one has been crazy enough to find out what would happen Even if i didnt know what it was for Id probably figure on installing it since Comptech did actually put it in the kit
Old Jan 29, 2009 | 11:15 AM
SRR's Avatar
SRR
like i said earlier i have experience with boost, this is not my 1st or 2nd or even 3rd boosted vehicle/ honda, i know what the esm does and that would not cause the engine to blow...
the esm tricks the stock ecu from seeing boost, the moment the stock ecu starts seeing boost its not going to run properly,
when i said i full throttle, i didnt floor the car all the way to redline, as soon as it started acting up i backed off.....
thanks again for the help
