Help finding greddy oil tap relocation
Old Jul 31, 2011 | 01:21 AM
whatthephucker's Avatar
Default Help finding greddy oil tap relocation
I bought a kit from another member that is greddy but he didn't include the oil tap relocation where you can jsut screw on to the oil pan bolt. I been looking around to see what i can use but i can't seem to find it anywhere. I look at the banjo but i can't seem to find one that fits the 5/8 oil holes. Do you guys know where i can get that greddy oil tap because greddy doesn't sell it anymore. I don't want to tap oil pan because that's more money.
Old Jul 31, 2011 | 02:18 AM
Nyther's Avatar
Tap the timing chain cover? you wont need to remove the oil pan this way...
Old Jul 31, 2011 | 03:26 AM
I am trying to get that oil bolt tap that greddy has that goes into where you would drain your oil from. So you dont have to drill to tap it
Old Jul 31, 2011 | 03:36 AM
Nyther's Avatar
I know, but if it's impossible to find you could consider the timing chain cover as an second opinion...
Good luck!
Old Jul 31, 2011 | 06:04 AM
s2knoob89's Avatar
Use this http://www.summitracing.com/parts/FRA-461014/ with one of these http://www.summitracing.com/search/D...?Ns=Rank%7cAsc Your welcome.
Old Jul 31, 2011 | 07:08 AM
jefferyg32's Avatar
^^ exactly what i was going to say^^
#10 MALE JIC TO 14MM X 1.50 CONCAVE is the right size and then all you need is a -10 pushlock fitting to 5/8 barb(your choice)
Old Jul 31, 2011 | 12:35 PM
will this work too
http://cgi.ebay.com/14MM-FUEL-OIL-BA...item5637ab2747
Old Jul 31, 2011 | 01:09 PM
s2knoob89's Avatar
Pretty sure that will not flow much at all. I say no. You might as well step up to -12 on the AN fittings too so that it will flow as much as possible.
Old Jul 31, 2011 | 05:54 PM
Yea! It seems like it can be clog. I would get the other but my greedy Turbo doesn't have the twistier on it. You have to mount tube with clamp
whatthephucker
Jul 26, 2011 02:27 AM
2006ap2
Aug 8, 2009 03:30 PM
pinoyk20
Feb 23, 2009 08:19 AM
dsddcd
Jan 20, 2009 02:15 PM
pinoyk20
Jun 23, 2007 05:37 PM
