Need some help
Old Jul 31, 2011 | 03:29 PM
manny-s2000's Avatar
Default Need some help
Hey guys last week I had some bad luck. My headgasket gave way, I now am taking out the high comp pistons and swapping them for 9.5:1 cp pistons the rest of the block and head was done before. Now the thing I need to know is, on the SOS kit the standard pulley was netting me 12-13 psi (13:1 comp and e85) now that I am dropping to 9.5:1 comp what sized pulley do I need for roughly 16psi?
Forgot to mention I am running the 1200 novi on a built f20c. What's the max psi you guys would run on the 1200 with a built engine?
Thanks in advance to everyone who responds.
Old Jul 31, 2011 | 04:51 PM
Suzuka_Joe's Avatar
you should talk to who ever is tuning your car and SOS since you need their pulley
Old Jul 31, 2011 | 05:07 PM
Unfortunately most tuners we have access to here in Sydney don't know to much about these kits etc etc since there isn't many people who build s2ks here. But I will def get in contact with SOS. Thanks
Old Jul 31, 2011 | 06:59 PM
Deception's Avatar
SOS website says for every point of compression drop you lose 1psi of boost.
So you need roughly 2 sizes smaller than a stock motor would need to hit a certain psi.
Old Jul 31, 2011 | 07:05 PM
s2000Junky's Avatar
Well, I'd max out the 18-20psi with that blower on a stock motor, so I'm probably the wrong guy to talk with.
Old Jul 31, 2011 | 10:13 PM
Ok so if I was netting 0.85 bar which is like 12psi before, I have to take away 3.5 psi loss because of 3.5 compression drop. So the standard pulley will make 8.5 psi on a 9.5:1 compression motor on e85 does that sound right to you guys? It seems odd to me for some reason!
Old Jul 31, 2011 | 10:52 PM
DFWs2k's Avatar
Why are you lowering compression if using e85?
Old Aug 1, 2011 | 12:27 AM
I don't want to risk blowing the engine.. I am rather safe than sorry. My engine was 13:1 comp before because it was an all motor build which I wasn't happy with so I went sc instead.
s2kbtos
Apr 9, 2017 07:50 PM
EriS2k
Jun 17, 2015 04:27 PM
MIs2000
Dec 30, 2011 02:14 AM
s4play
Nov 23, 2011 12:11 PM
bimmerpowa
Mar 20, 2007 08:01 PM
