Help me build my motor.....
I just got a new (used) short block without a head. I am looking to build her up with the strong guts to take a turbo kit, the way it should be done without using unobtanium. Where do I start, as in if you could build it your way, what would you do, cost is a factor, but I want to do it right. I am looking for ratios and specifics on pistons rods etc. Help a long time member out here, I know about the bolt on stuff, but not too much about innerds.
MAtt
MAtt
I just went all out !! sleeved block JE pistons Crower Rods..everything for A little over $3k....Give TSR Performance a call we will hook you up !! Call and ask for Mike!!410-760-5995.. even tho you live in socal we can still hook you up!!
Exactly, spend the least you can. JE pistons, stock or crower rods depending on how much power, your choice on sleeves. Shouldn't be too much over $2k on those main parts. Then some nice head bolts a few other misc. parts. Get an installer or install it yourself and you're done.
Here's a setup with claims of 725WHP and 541 torque at 25lbs of boost on C16 gas. Haven't actually seen the dyno yet.
http://honda-tech.com/zerothread?id=1169077&page=1
Benson sleeved block, CP pistons, Cunningham rods, balanced & polished crank, head ported/polished, Supertech springs, valves, and ti retainers...9:1 CR.
Sleeving process: http://honda-tech.com/zerothread?id=565375&page=1
thanks guys. RZFD, I am looking for a strong, streetable, 400 rwhp. I am not looking into making it the highest hp S2000 out there. Money is a factor only because I am a cheap bastard. I am looking for a strong motor with the best bang for the buck. I want to build it just enough to not blow up any time soon.
sounds like a 2.2 ish boar, with sleeves, a hg, strong studs, and rods is all I need??? Thanks again, like I said, I have been here a long time, but have never built a motor up, so thanks for the info.
What else do I need to know?
MAtt
MAtt
