why has meth not really been used as a option until just recently, as far as I know there are just a hand full people running it. Mostly greddy kits. Is this because most inline pro guys use a 3mm. Are there any inline pro justs running stock compresion and meth? Just woundering?
Here's the Aquamist I'm running with a Hydra standalone ECU
I'm not familiar w/ the AEM, but it should be capable enough to drive the injection thru a PWM output into the Aquamist trigger. Just set it to PWM and get an output from the AEM.
Configure a 2d map in the AEM thru the a PWM output and presto! you'll have a load-based injection sytem.
And..... NO you can not use fuel injectors as they will corrode and are simply not designed for water-alky injection
check it out
I made this GIF of the system using Aquamist's diagram
You are correct, I did find unless you are using near 100% meth a regular injector will not work.
You guys are both missing one thing, what is the point of the electronics. I can can contol the injector based on many different parameters not just the ones limited to the controllers I/O. Secondly, why add all those extra wires? I m trying to simplfying the entire install as much as possible without using a hobbs switch and single stage spray.
If I were to add this in my STI, yes, it would be perfect.
The 2C with a flow switch and level switch is as simple as I can get it. Turns out one of the main US aquamist importers is located a few miles from my house. http://www.aquamist.co.uk/cp/sys2c/sys2c.html
So I beilive I am going to break down and pick a meth addition but, which kit to get.
I have decided the only way to do this correclty is with a pulsed nozzle driven of my nitrous output. The only kit I could find with this is Aquamist 2C but they don't have the some of the features I want. That the AEM and Snow have and they are very pricy. Has anyone made their own yet? Can you use a regular injector?
