HELP! Vortech!
Old Aug 1, 2008 | 11:45 AM
sirguy01's Avatar
Default HELP! Vortech!
Alright I'm having a bit of an issue with my supercharger unit. I wanted to up the boost from the stock pulley so I called Vortech to ask them which pulley would best suit my needs I was hoping to be near the 400whp range. After speaking with them and reading on the forums. So Vortech sends me 3.8" pulley.I am running a Ultimate Racing Front Mount kit, so there would be roughly a 2 psi boost drop. We ran the pulley on the car and it idled fine and it would go into boost like normal. I did not further examine the boosting situation as I was un-tuned for this pulley.
So at the dyno, we get into our issues. We make one pull, the car makes 302.whp and 188ft lbs @7psi. The issue is that the car is only making 7psi @9k. We've checked for boost leaks and everything checks out. So we turn the car off, shuts down normally, as the charger is winding down the belt walks off the charger pulley.
I've heard of belt slipping but rarely do I hear about belts walking off pulleys like so.
So for now I have taken the belt off the pulley just in case something stupid happens and it gets caught up in something.
I've contacted vortech, however their " tech" guys are not in today so I will have to wait till next week before anything can be done.
If anyone has any ideas please shoot them this way.
Here are some pics of the set up. If anyone needs anymore info please let me know
Thanks in advance
If you got nothing good to say say it anyways, im looking for a reason to unload this car right now.
Old Aug 1, 2008 | 12:46 PM
Sideways's Avatar
It appears the belt was loose so you didn't get the boost you were looking for and the belt came off because it was too loose too.
Old Aug 1, 2008 | 01:02 PM
sirguy01's Avatar
we tightened the belt as much as we could. I used 49inch belt for this set up is what most ppl are using on there it's either that or 50.
Old Aug 1, 2008 | 01:06 PM
Sideways's Avatar
Are you properly tightening the belt? Do you release the lock nut before adjusting and retighten it when adjusted?
Old Aug 1, 2008 | 01:07 PM
lil dog's Avatar
PM'ed
Old Aug 1, 2008 | 02:22 PM
sirguy01's Avatar
what is the proper procedure to tighten?
Old Aug 1, 2008 | 02:37 PM
John_Z's Avatar
You've got an 8 rib pulley and you need a 6 rib. Your 6 rib belt is obviously not lined up with the top and bottom pullies.
Old Aug 1, 2008 | 02:38 PM
Sideways's Avatar
Release the lock nut on the arbor. Adjust with screw adjuster. Retighten nut on arbor.
Nut on Arbor. This is done from underneath the car.
Adjusting screw.
If you just twist the adjusting screw without releasing the lock nut it will screw up the adjusting screw and it will break. Vortech reports this happening quite frequently.
Old Aug 1, 2008 | 02:40 PM
9kFever's Avatar
good catch. And also like sideways said you need to loosen the 11/16th bolt on the back side of the adjuster pulley. Then you can adjust the adjuster screw/arbor. Clockwise will make it even more loose.
Old Aug 1, 2008 | 02:42 PM
Sideways's Avatar
[QUOTE=John_Z,Aug 1 2008, 03:37 PM]You've got an 8 rib pulley and you need a 6 rib.
