HFC and stock exhaust?
Old May 27, 2010 | 06:08 AM
mezzfin's Avatar
Default HFC and stock exhaust?
New GReddy kit installed and tuned got me to 264/218 @9psi with stock everything else. Was told that was about as good as it gets with the stock exhaust. Question: looks like a Berk HFC is a relatively inexpensive improvement in flow, but is it a waste if the rest of goods stay the same? I would also take the time to get a new 4 bar MAP, bump psi to 10, and retune. Am I dreaming?
Old May 27, 2010 | 06:19 AM
siadam's Avatar
If you want to keep it quiet and emissions compliant, get a cutout.
Best of both, although this will require a retune.
Old May 27, 2010 | 06:48 AM
devs2k's Avatar
Most people with the Greddy kit have great results with a 70mm cat back with either the stock cat or a HFC...
I ran 7psi, 70mm catback, stock cat, and made 300whp on a dynapack, figure 275whp on a normal dyno
Old May 27, 2010 | 07:09 AM
TRBOKEV's Avatar
The stock cat is very restrictive. A HFC and stock exhaust would be a good middle ground IMO.
Old May 27, 2010 | 12:44 PM
Carbon Blue's Avatar
can you still pass smog with a HFC??
Old May 27, 2010 | 12:59 PM
Torque Obsessed's Avatar
Depends on where. CA visual inspection may fail. Other states might not notice. OBDII emissions check won't notice anything as long as your car is running well.
(Berk HFC and Fujitsubo exhaust were my first two mods to improve my Greddy kit.)
Old May 27, 2010 | 06:17 PM
Revenge's Avatar
Get a HFC or better yet a TP it's worth it on the greddy kit with stock exhaust. Probably the best mod for the kit. Don't do a cut out, greddy can't handle it.
Sophotrope
Sep 3, 2018 08:50 PM
mezzfin
Jul 19, 2010 09:23 PM
samsam5886
17
Apr 29, 2010 02:44 PM
Richee
May 23, 2007 07:01 PM
Antonov
Dec 9, 2006 05:13 PM
