I am running a SOS kit and going a bit more boost than you, although on e85. The stock bov we have is a plastic bosch valve. I wasn't sure I'd its capabilities for high boost, but have been reassaured that it will be fine, even and 15psi.
Hope this helps. I'd leave it alone unless you are wanting to change it
Originally Posted by MasterForce,Jan 22 2010, 10:26 AM
is it just plug and play or is there some kind of modification i need to do?
I'm not sure which bov are compatible with which chargers, but typically they just have to weld on a flange so that you can attach the bov to the mounting surface that is provided. There are quite a few threads on the topic. It isn't too hard for most shops to make the flange.
so how do you adjust for the proper boost level on the stock BOV. mind you I am in Iraq and cant go look. I am just tryin to figure it all out so I can get right to work when I get home.
