Hign Compression Vs. Low Comperssion
Old Aug 22, 2006 | 04:58 AM
c_me_go's Avatar
I have a buget of 12k... but I want to drop a turbo and cluch and do the bottom end... I hope that will be enough...
Old Aug 22, 2006 | 07:16 AM
John_Z's Avatar
That is cutting it close and some may say it's not enough depending on what turbo kit you go with. Labor for a turbo kit and clutch install will hurt your budget. You will also need engine management, tuning, and incidentals along the way.
If you can swing it, build the bottom end rather than the headgasket route.
Old Aug 22, 2006 | 07:35 AM
Spoolin's Avatar
Just so you know, compression is compression. Whether you run 10 psi on 11:1 compression, 13 psi on 10:1 compression, or even 16 psi on 9:1 compression, you are going to end up with the same overall total engine compression of around 18.5:1 under boost. The biggest difference is where your turbo is efficient; low boost or high boost? And you will loose more torque the more you lower the engine compression before boost, so your torque curve will be different. Basically, the higher the compression on the engine before boost, the more low end torque you will have.
I am currently going to be running 10 psi on my stock 11:1 compression because I like the lower torque and my turbo is more efficient at lower boost.
Old Aug 22, 2006 | 07:50 AM
c_me_go's Avatar
So I am not really sure what I should do then... I love HP but its really all about TQ.. So if its basically the same.. why should I build the bottom end instead of just adding a bigger head gasket??
Old Aug 22, 2006 | 09:51 AM
Spoolin's Avatar
Building the bottom end will insure longer life of the engine and it will be able to take more abuse. If you have the money to build the engine, then by all means do it; it's the best way to go. I was stating the points about just putting a headgasket on to lower compression and the pros and cons of it. It all depend on what type of turbo you go with and how you set it's map up. The question you have to ask yourself is; is it efficient at lower or higher boost? This will ultimately determine what compression ratio to go with on the motor.
Old Aug 22, 2006 | 10:09 AM
c_me_go's Avatar
Well .. I was thinking of dropping the Compression to somewhere in the 9s.. I will also be buying a kit from you Cody.. So you tell me.. what is the best thing to do?? I have to buy new pistons and rods because i broke the OEM ones.. but my problem is which psitons and rods to buy??
Old Aug 22, 2006 | 10:55 AM
geists2k's Avatar
What are your HP goals?
If you plan to go north of 400Hp, from everything I have researched, it's best to build the bottom end. Otherwise the factory forged internals should work well unless you find really creative ways to abuse them.
If you must rebuild due to a blown engine, I have heard Pauter rods and CP pistons are excellent. Don't forget the sleeves...
Old Aug 22, 2006 | 11:11 AM
c_me_go's Avatar
well I just finished talking to honda.. they told me that it is not under warrenty.. So I guess i will have to build the block from the bottom up...
(If you must rebuild due to a blown engine, I have heard Pauter rods and CP pistons are excellent. Don't forget the sleeves... )
I will keep that in mind when I am going to buy new pistons and rods.. Do you think its better to drop the compression??
Would like to have anywhere from 380 to 450 HP..
Old Aug 22, 2006 | 03:55 PM
honda9krpm's Avatar
Choosing compression ratio is very important and it depends on what you want to to do with your car. The aim is to get as high effective compression ratio as you can with minimal risk of detonation. Effective compression ratio is static compression ratio + boost. There is a formula for it on the web if you are keen.
If you want to use the car for daily use with low, to medium boost then a higher static compression ratio is ideal. This will give you more midrange power and more importantly good fuel economy.
If you want a high power, high boost, drivetrain killing engine then a low static CR ideal.
Do a search on s2ki for the piston options. From memory there are 8-10.5:1 ratio pistons available. There are higher ratio too but not ideal for FI purpose. IMHO the forged pistons are all very similar. There are only less than a handfull of places where the forged metal for the pistons came from. What you pay is for the brand, design and quality control.
Hope that help. It's a new learning curve with engine rebuild, but it's fun one
Old Aug 22, 2006 | 04:31 PM
c_me_go's Avatar
Yes.. It does help alot... I am shooting for a compression raito around 9 or so.. Def less than 10... Its not my daily driver but I def dont want a track car either... I just want a high boost with lots of mid to high end power... Trying to make my engine bulllet proof...
