Hondata Turbo Question
Old Jan 22, 2011 | 01:28 AM
Mijae007's Avatar
Default Hondata Turbo Question
i have a 2008 s2000
Is there anything else in addition to the flashpro in terms of engine management that I will need to run a boosted S2000?.....searched and no concise answer
Old Jan 22, 2011 | 08:06 AM
Gernby's Avatar
Former Sponsor
You'll need bigger injectors, and possibly a different MAP sensor if you plan to run high boost levels. If you want boost control, you'll need something separate for that too.
Old Jan 22, 2011 | 10:38 AM
Mijae007's Avatar
thanks,
im talking just for the engine management system tho. i have inj, etc etc. so all i need is flashpro and map sensor?
with flashpro, you dont need anything additional from hondata to run boost?
Old Jan 22, 2011 | 11:43 AM
PsykotiK's Avatar
u need a boost solenoid
Old Jan 22, 2011 | 12:02 PM
DFWs2k's Avatar
Unless you run off waste gate spring
Old Jan 22, 2011 | 12:28 PM
TonysMI4's Avatar
no you dont. The hondata flash pro cant control boost. so you dont need that. you can just get a manual boost controller. Or just run off the spring.
Old Jan 22, 2011 | 01:24 PM
Mijae007's Avatar
thats interesting, im pretty new to turbo and tuning so this is all new to me. running just off the spring in the wg is kind of unreliable no?? manual boost controller seems liek the way to go.
Old Jan 22, 2011 | 01:26 PM
Mijae007's Avatar
also what if you wanted to run two diff settings? like high boost and low boost? i would imagine you would need a boost controller. swapping out the spring everytime u switch boost levels would suck. am i on the right page here?
Old Jan 22, 2011 | 02:38 PM
EternalLx's Avatar
You can use AEM tru boost to control the boost
Old Jan 23, 2011 | 06:07 AM
Gernby's Avatar
Former Sponsor
You don't need to replace the MAP sensor unless you go with a high boost setup. I think the stock sensor is good up to 10 PSI, IIRC.
