Hooking up VAFC with ESM box on Comptech SC
Old Oct 1, 2007 | 05:46 AM
Silver S2k4's Avatar
Default Hooking up VAFC with ESM box on Comptech SC
I have a comptech SC and a VAFC one. I am using the VAFC to tune but would like to use it also to see peek boost levels. I am afraid that if I hook up the ESM before the VAFC then I will not be able to change the map signal that the VAFC uses to tune since the ESM black box will cap it anyway.
How do you guys have it hooked up.
Is there a way I could wire up the black box in between the VAFC so I could see actual boost but still adjust it after it has been capped?
Old Oct 2, 2007 | 07:36 AM
Anyone supercharged and have a VAFC?
Old Oct 2, 2007 | 11:14 AM
pdexta's Avatar
I posted a thread somewhere. This is what I did...
FWIW, I wired the VAFC between the ECU and the ESM. As seen in the diagram.
Old Oct 2, 2007 | 11:35 AM
Soul Coughing's Avatar
think about what you are doing. the map sensor is getting a voltage for the amount of air, which the VAFC is then going to corrupt by a percentage, then it will be stopped from going to a certain voltage due to the ECU's inability to see positive pressure. (ESM) Where the map sensor stops working, the FMU is going to take over for the map and add more fuel. I ran a similar setup to yours when i first went FI, and i wouldn't do it again.
OT, Scott's w ay is how i set up the VAFC with ESM. I was able to get the actual voltage for the pressure the map was seeing, and then have the ESM stop the voltage from messing up the ECU.
Old Oct 2, 2007 | 11:53 AM
So did I, but I wish there was a way to see actual boost but still be able to alter the signal.
Old Oct 2, 2007 | 12:17 PM
Spec_Ops2087's Avatar
^^ Get a boost controller
Old Oct 3, 2007 | 05:29 AM
pdexta's Avatar
SC Boost Controller = Pulley
Old Oct 3, 2007 | 01:11 PM
Whops I mean't to say boost gauge
Then you can alter the signal with the VAFC and still read boost
Old Oct 3, 2007 | 01:15 PM
I have a boost gauge as well.
I was trying to do something a little different but I guess it won't work.
Does anyone know if the VAFC would still work if the black box was between it and the ECU?
Old Oct 3, 2007 | 04:07 PM
AusS2000's Avatar
The definitive fact is the ECU can't see boost, and it's controlling your injectors. So the ESM should go between the VAFC and the ECU and hence the VAFC will have no effect above ambient pressure. The VAFC is seeing the actual MAP signal so doubles as a boost gauge.
You can connect them the other way around though. What you have to do is make sure the car is running a little rich throughout the boost range, then only use the VAFC to pull fuel (It basically always sees 2.93V when in boost and sends a lower signal to the ECU).
Either way, it's ghetto tuning.
wils2k
May 9, 2006 04:04 PM
Redline Drift
Feb 15, 2004 03:35 PM
ayelien
Jan 26, 2004 10:09 AM
pfb
Feb 13, 2003 01:03 PM
pfb
Mar 25, 2002 10:13 AM
