how do you install boost gauge?
Old Nov 10, 2008 | 10:08 PM
azride1983's Avatar
Default how do you install boost gauge?
i have a defi racer boost gauge for my kw sc..i'm wondering how to install the gauge? where do you put the vacuum hose and the wiring? if anyone can help it'd be much appreciate it..thanks guys..
Old Nov 11, 2008 | 12:03 AM
smirfs2k05's Avatar
I've seen people tee the pcv hose since its the only vaccum line coming off the manifold.
Old Nov 11, 2008 | 05:50 AM
UsmcSway's Avatar
As your looking at the car from the bumper, its the vacuum line on the intake manifold closest to the rear of the car. Put a T in that and run the boost line thru the firewall to your boost gauge. SEARCH FTW
Old Nov 11, 2008 | 06:30 AM
SuzukaBlueAP2's Avatar
you sure it was the PCV?
I tee'd the nipple that has the vacuum source for the FPR.
Old Nov 11, 2008 | 06:51 AM
UsmcSway's Avatar
yes thats true. Its the third line back.
Old Nov 11, 2008 | 07:02 AM
8kGoodENuff's Avatar
FPR?
Andre
Old Nov 11, 2008 | 07:04 AM
sorry...fuel pressure regulator.
the neon green line drawn at the top of the engine bay here is where you would tee into.
Old Nov 11, 2008 | 09:18 AM
azride1983's Avatar
that line is use for the kw sc. its cut and has a Tee outlet to run into the bypass valve
Old Nov 11, 2008 | 02:44 PM
OJRKraftWerks's Avatar
I recommend teeing into the line that goes to the bypass valve or the one SuzukaBlue pointed out up top. They are both tied to the bypass valve anyways...
-OJR
Old Nov 11, 2008 | 04:12 PM
azride1983's Avatar
thanks ....and the lighting wiring should be located in the fuse box right?
