How does this turbo setup sound?
Old Feb 6, 2008 | 07:36 PM
03silver2000's Avatar
Default How does this turbo setup sound?
Turbo-GT3582R
Manifold-Inline Pro
Headgasket-3mm Inline Pro Headgasket
Blow Off Valve-HKS
Wastegate-44mm Tial
Downpipe-Inline Pro
Gauges-Autometer
A-Pillar- Science of Speed
Ecu- Aem ems 1052
Intercooler and piping-Spearco
Injectors-550cc Rc
Fuel pump-Walbro 255
all coolant and oil lines- from a nearby speed shop
Head studs-Arp
ok so i have a few questions... will i be able to get 500whp out of this setup?
Will i need to relocate my oil filter? battery? or fuse box?
will i still be able to keep my ac?
does this sound like a good setup?
and would it be a definate to have to update to have to upgrade my differential?
and i also want to be able to run pump gas
Old Feb 6, 2008 | 07:48 PM
1qwikef's Avatar
get bigger injectors. if you want around 500whp your going to need 750's or bigger
Old Feb 6, 2008 | 07:55 PM
so go with 750 cc injectors or maybe 1000cc also the manifold im not 2 sure about what is a real good manifold for the s i wouldnt want to lose my ac or have to relocate my batt or filter or fuse box if i dnt have to any suggestions
Old Feb 6, 2008 | 08:02 PM
DjSkrilla's Avatar
The inlinepro manny is fine. I'm pretty sure you'll have to notch the frame to fit that turbo though. Someone correct me if I'm wrong.
Old Feb 6, 2008 | 08:04 PM
Spec_Ops2087's Avatar
^^ Yes you will, also the tial 44mm is not a direct bolt on. The manifold is designed for a direct bolt on of a 38mm wastegate.
Old Feb 6, 2008 | 08:13 PM
afwfjustin's Avatar
It'll be easier to get 500 out of a tubular. If you don't want to worry about cracking go with a short tubular like the Lovefab mini-me. Also, I'd go with 750+ injectors. The 550 is not a good idea for turbocharged cars above "stock" boost levels.
Old Feb 7, 2008 | 04:22 AM
busterpit23's Avatar
PM sent
If you use the Inlinepro setup you won't have to move the battery or worry about melting anything. You will have to notch the frame especially with a GT35R.
Old Feb 7, 2008 | 01:40 PM
but with any of these i wil be able to keep my ac correct
Old Feb 7, 2008 | 01:49 PM
Swift_azn's Avatar
yes you'll need a oil relocation kit.
Old Feb 8, 2008 | 02:38 AM
SentTwoKill's Avatar
Full-race.com
just get every thing from them and S.O.S.
