how to install ARP exhaust studs?
Old Oct 16, 2010 | 12:10 PM
08s2000CRbackinblack's Avatar
Default how to install ARP exhaust studs?
ive already have removed my stock studs and was wondering how you guys were installing your new exhaust studs? any specific procedure or torque specs? use light threadlock or anti-sieze? any advice would be greatly appreciated!!!
Old Oct 16, 2010 | 05:29 PM
i know someone in the FI section has installed these before!!!
Old Oct 16, 2010 | 06:12 PM
TRBOKEV's Avatar
LOL
Screw the studs in, double nut with a stock nut to tighten, then put the manifold on and tighten from the middle outwards. I didn't torque mine, it's impossible to get a wrench in there.. I just tightened the sh* t out of them and have had no issues.
Old Oct 16, 2010 | 06:50 PM
dsddcd's Avatar
I just used an allen wench to run them in all the way and tightened just past hand tight.
Old Oct 16, 2010 | 07:08 PM
1SlowSi's Avatar
Lots of moly lube on the threads and both sides of the washer. Like DSDDCD said, just barely past finger tight. Torque the studs down in 3 steps. I did a first step just to get the threads started and the head to seat a little. 20- 40-60-90. If you hear any squeaking while torquing, loosen and try again. Maybe add more moly lube.
Go back through every stud to see if they are all at the given tq spec.
Old Oct 16, 2010 | 07:30 PM
m R g S r's Avatar
thats for headstuds....he is referring to the exhaust maniold studs. no way that tiny stud is going to take 90ftlbs and no need for moly lube
Old Oct 16, 2010 | 08:42 PM
dc2-2-ap1's Avatar
thinking about getting a set can you post the part number so i know what the correct ones are. thanks
Old Oct 16, 2010 | 08:49 PM
1SlowSi's Avatar
Opps lol.
Old Oct 17, 2010 | 05:26 AM
bruthaboost's Avatar
Whenever I put in new studs I true up the threads with a tap and clean them up with carburator cleaner.
Old Oct 17, 2010 | 07:33 PM
Deception's Avatar
If you are using a Rev hard/ IP log manifold you will need to leave off the 2 or 3 studs closest to the front of the motor when you initially mount it. Once its in place, you can put them in and tighten down the nuts.
