How to keep boost at 8-9#'s
That wastegate has a 7 pound spring I believe. You can probably boost 8 consistently, but if you want to go more than 8 you'll need a boost controller I think since you're using the e-manage. The EMS lets you set the boost though
~Justen
How far off are you over-boosting to right now? You can try to go with a lower rate spring and that might help you.
I carry the Tial 44mm and have used it and the 46mm for a while now and they control boost very well. You would need to get either and adapter flange or weld the 44mm flange on there and then make a new dump tube.
What are you using to control timing btw? Maybe your timing tables are a tad too retarded.
The kit isn't on the car yet. I am just trying to be as cautious as I can before the install. Which will be in the middle or end of march. I am running a greddy emanage blue with the boomslang adapter. I just don't want boost creep getting over the 9.5# mark.
manifold design.....if the exhaust gases have to turn 90 deg. or greater that really hurts the flow to the WG....
so if the manifold is designed well, it shouldn't be a problem with a 38mm......
AusS2000
Jun 19, 2007 05:38 PM
AirborneS2K
Jun 16, 2007 01:26 PM
S2KAtlanta is going to be chock full of turbo'd S's...
