How this look for my Electric cut-out?
Old Aug 4, 2009 | 07:21 AM
JoeyBalls's Avatar
Default How this look for my Electric cut-out?
Well the Downpipe with the PFAB ELT manifold i 3" so I will run a 3" test pipe, however I will also add one of these
QTEC30CP Single 3" Electric Valve, Wiring Harness and 1 Toggle Switch w/10300 Stainless Steel Cutout Pipe $215.00
Question I have is, where do I place it, prior to the Test pipe? I would imagine I would have to cut away some piping from my exhaust, because adding this will make my exhasut too long?
Anyway, anyone hear of these guys?
Heres the link, and the product number is QTEC30CP
Go to where it says "application chart"
http://quicktimeperformance.com/QTEC/
Old Aug 4, 2009 | 08:38 AM
spectacle's Avatar
If you're running 3 inches all the way back, why mess with the cutout? I'm assuming you're going to run some super quiet restrictive mufflers and want that little extra whenever its fun time?
Old Aug 4, 2009 | 08:43 AM
sbrodacz's Avatar
Banned
I haven't heard the greatest things about qtp, but looks good.
Old Aug 4, 2009 | 08:59 AM
Soul Coughing's Avatar
i have one of these installed on my car. I have put about 10k miles on it without issue.
I installed it where the test pipe was. It basically dumps post down pipe, pre stock exhaust.
Old Aug 4, 2009 | 09:01 AM
JoeyBalls's Avatar
ok, so then I would not even need to buy a test pipe?, just this?
in case anyway wants to know why I am re-doing my setup, its cause of SoulCoughing, one ride in his car and I was done
Old Aug 4, 2009 | 09:05 AM
sbrodacz's Avatar
Banned
No you would not need a test pipe as long as you put the cutout before the cat
Old Aug 4, 2009 | 09:08 AM
JoeyBalls's Avatar
Was nt planning on having a cat either, basically DP/Cut-out/ Invidia exhaust, I mean I could use the OEM cat, but then I would have to cut some piping off, which I will probably have to do anyway
Old Aug 4, 2009 | 09:12 AM
sbrodacz's Avatar
Banned
You can do that too. On my last exhaust I just had a straight 3" pipe from the down pipe a muffler. No Will have a straight 4" pipe from the down pipe no muffler. It wouldn't be a bad idea to put the cat back on just to keep it quiet until you open the cut out.
Old Aug 4, 2009 | 09:29 AM
JoeyBalls's Avatar
yeah, plus it would make me "lageal" just in case
Old Aug 4, 2009 | 01:18 PM
minitoyota's Avatar
Joey.. I can help you set this up if you want. Souls car is at my house now actually and we are redoing his DP/cutout setup. You're not going to have room to run a cutout and stock cat, basically the cutout needs to go where the stock cat sits. Its takes up a ton of space and your car is lowered so you don't want things hanging and potentially scraping. The exhaust is directly connected to the mani/turbo, if it takes a hard enough hit it will cause damage/cracking... Also remember, by dumping exhaust directly under the car you run the risk of burning everything in its path. A turn down would be ideal off the open side of the cutout.
I wouldn't worry about Legal.. Not with an open dumptube atleast.
I believe QTP is local to us so you can go visit their shop/warehouse if you want to see the stuff first hand.
