How many miles on your sleeved engine?
I figured I'd throw this in here first, since the FI folks are the most likely to sleeve their engines.
Given the scarcity and cost of used blocks, I am wondering if a sleeved block is a potential alternative. I understand the longevity may not be as good as an OEM unit but if a sleeved block can last at least a certain number of miles then maybe there is an alternative for us instead of just looking for used blocks.
Conventional wisdom around the boards is that the F20/F22 does not take well to sleeves and fail after so many miles due to the high thermal cycling that the F20/F22 goes through and the differing materials of sleeve and block. Going through old posts, it seems like sleeved engines can last a number of thousand miles. The question is how many?
A simple cost analysis can help us determine how many miles the engine should last. For the sake of argument let us we assume that a used OEM block will go 100,000 miles before needing to be refurbished. In today's market, a used engine will start around $4,000. So that is about 25 miles per $ or a 25:1 mile to $ ratio. Say we spend $1500 to have a block sleeved and re-built up with OEM spec components. We should then expect the engine to last 37,500 miles (1500*25 = 35,000).
The question I have then is are there any sleeved engines out there approaching these miles? If you have a sleeved engine, how many miles do you have on it? Wet or dry sleeve? Brand? Coatings or anything extra?
xskyx
Australia & New Zealand For Sale and Wanted
Jan 7, 2017 11:28 PM
