How to maximize the Vortech Supercharger
Old Apr 22, 2008 | 06:28 PM
Harpoon's Avatar
What's the header in your avatar? Is it coming out from Asura along with the new exhaust optimized for FI?
Old Apr 22, 2008 | 06:50 PM
Sideways's Avatar
[QUOTE=Harpoon,Apr 22 2008, 07:28 PM]What's the header in your avatar?
Old Apr 22, 2008 | 07:16 PM
9kFever's Avatar
Originally Posted by Sideways,Apr 22 2008, 05:08 PM
Every engine will vary. The S trim should see 15 or 17 psi. Three point nine looks like a good choice for the AP1.
v2 SQ=S trim?
Old Apr 22, 2008 | 08:00 PM
Sideways's Avatar
Originally Posted by 9kFever,Apr 22 2008, 08:16 PM
v2 SQ=S trim?
SQ= super quiet
It is the S trim with a quieter gearbox.
Old Apr 22, 2008 | 09:31 PM
WindchaserS2K's Avatar
Thank you for answering so much question for me on the head build
Old Apr 22, 2008 | 10:22 PM
Asura's Avatar
Originally Posted by Sideways,Apr 22 2008, 06:50 PM
It's my go fast crack pipe in the avitar.
Asura I don't really know but we expect big things from that lad soon.
Old Apr 23, 2008 | 03:21 AM
Danks2k's Avatar
And I just bought a 3.8" pulley 2 weeks ago according to your old chart. I am only planning on running a 9k rpm redline would this pulley still work well for me? Or should i get a 3.9" or 4.0" made.
Old Apr 23, 2008 | 04:21 AM
Sideways's Avatar
It's ok to go a hundred or two hundred rpms beyond for a millisecond. Five or eight hundred beyond is not something you want to do. The 3.8 pulley should work out fine. I'm waiting for a 4.15 pulley to go with the a 9600 redline.
Old Apr 23, 2008 | 05:31 AM
s2000442's Avatar
Have you done anything to strengthen the engine for it to be able to spin at 9600 rpm? If so what have you done? Thanks
Old Apr 23, 2008 | 06:36 AM
Sideways's Avatar
The bottom end was assembled and blueprinted by Mike Laskey. It's his "cookie cutter" block. Stock bore and stock stroke 2 liter. CP pistons, Pauter rods, Benson sleeved block.
The head is an Alaniz competition head with a mumbo jumbo mix of parts including Supertech, Honda, Alaniz, Manley, Eibach, Skunk 2, and so on.
Tony Fuchs did the assembly including studs and inserts. Goodies include a 70mm BDL throttle body, GM 3 bar MAP sensor, modified intake manifold, 4 inch cold air intake and a Honda head gasket.
The engine is good to 10,500 rpm but the cams don't support that speed.
That said, my factory f20c bottom end was good to 9500 rpm.
This guy thinks I'm full of **** so don't believe me.
