How much boost?
Old May 20, 2005 | 03:20 AM
synapse's Avatar
Default How much boost?
Guys, How much boost are you guys running out of the box with the Vortech, Comptech or turbo, stock injectors, stock compression ratio and without changing the timing advance.
What's the most you have run on a completely stock setup and pump gas without pinging?
I just finished up installing my turbo and wanted to get a gauge for what to expect when tuning. Thanks.
Old May 20, 2005 | 03:45 AM
Kwando's Avatar
when everything is done and complete (haven't started yet) i plan on running only around 6 psi... 450 injectors... stock compression... no timing adjustments.
Old May 20, 2005 | 08:25 AM
nsxinsac's Avatar
From what I researched, anything above 8psi for CT SC needs injectors and tuning to be safe. Anything above 9psi is risky but has been done and hope to hear members long term use. If its safe, I might go to 10-11psi.
Old May 20, 2005 | 08:35 AM
wannabuy's Avatar
I will be running around 8psi with stand alone and pro tuning. Both on and off the dyno. Most recommended to have that tuning done. Sometimes everything can't be done on just the dyno.
Old May 20, 2005 | 09:38 AM
yellowknockers's Avatar
Will be going for something between 15-20lbs of boost in my setup. Motor build has lowered compression down to about 9-1.
Old May 21, 2005 | 06:29 AM
JDMKID35's Avatar
Banned
I ran 18 psi stock pistons and rods.. with a 3mm headgasket and made over 500hp on 100 octane pump gas!!
Old May 21, 2005 | 07:10 AM
Black Nugget's Avatar
Currently running the comptech supercharger w/ 7psi belt & pulley.. stock injectors, no tuning done. However I do have a VAFC1 & Frog Harness sitting in my room waiting to go on, just to lazy to take it for tuning
Old May 21, 2005 | 11:47 PM
synapse's Avatar
what did you guys gap your spark plugs down to? 25-30?
Old May 22, 2005 | 06:12 PM
EriS2k's Avatar
Waiting for my 10psi Pulley!
Old May 23, 2005 | 07:31 AM
SpoonS's Avatar
im 8lbs street and about 14lbs high boost and aquamist to be safe on high boost
