How much boost?
Guys, How much boost are you guys running out of the box with the Vortech, Comptech or turbo, stock injectors, stock compression ratio and without changing the timing advance.
What's the most you have run on a completely stock setup and pump gas without pinging?
I just finished up installing my turbo and wanted to get a gauge for what to expect when tuning. Thanks.
From what I researched, anything above 8psi for CT SC needs injectors and tuning to be safe. Anything above 9psi is risky but has been done and hope to hear members long term use. If its safe, I might go to 10-11psi.
Currently running the comptech supercharger w/ 7psi belt & pulley.. stock injectors, no tuning done. However I do have a VAFC1 & Frog Harness sitting in my room waiting to go on, just to lazy to take it for tuning
