How much boost can i run?
Old Mar 21, 2007 | 03:13 PM
1BAD4CYL's Avatar
Thanks ramo19 i will be ordering soon what will be a good price for the vortech sc and to have it installed?
Old Mar 21, 2007 | 06:02 PM
Spec_Ops2087's Avatar
10psi is the max I would go on stock internals constantly.
I'm boost at .5 kpa which is about 7.5psi now, and I'll be upping it to 8.5psi but nothing more. You'll need a headgasket if you want your engine to last any more psi then that.
Old Mar 21, 2007 | 07:24 PM
2QYK4U's Avatar
I currently have the inlinePRO turbo kit with a GT3071R turbo and am boosting 9.5 psi and made 352rwhp on a dynapack (very conservative tune--rich and little ignition advance). I recently purchased some new parts from Full-Race, along with a GT3567R turbo, and at 9.5 psi I should make close to 425rwhp on the same dyno. My engine is bone stock. I did purchase an inlinePRO 3mm headgasket, but won't have it installed until I have the head built.
I don't think the question is "how much boost can I run on a stock engine" but "what is the maximum power a stock block can handle". 9 psi on a stock block with the inlinePRO kit is VERY different from 9 psi with the Full-Race kit. So, I'd think more in terms of power vice psi.
Good luck!
Old Mar 21, 2007 | 07:26 PM
2QYK4U's Avatar
As a point in reference, there are MANY turbo K20A2s (RSX Type S engine) making 450whp on the stock engine. The F20/F22 has an advantage over the K20A2 as it has both forged pistons and rods.
Old Mar 21, 2007 | 07:33 PM
2QYK4U's Avatar
Also, the quality of the tune is HUGE! I cannot stress this enough.
Old Mar 22, 2007 | 05:25 PM
1BAD4CYL's Avatar
Thanks 2QYK4U for all the facts.its nice to talk to people who know there shit..
Old Mar 22, 2007 | 06:11 PM
2QYK4U's Avatar
I am far from being the most knowledgeable person on this forum. I know a little bit, and am on a quest to learn more! Good luck on your build!
Old Mar 22, 2007 | 06:15 PM
SPECIAL-OPS-S2K's Avatar
I've always wondered... why is it that I could say run 15 PSI with a GT35 and make X amount of hp to the wheels and if I were to switch to a GT30 I would need to run 19 PSI to make the same HP??? If the PSI into the intake manifold is the same wouldn't the HP be the same as well??? I know that is not the case but I am just curious if anyone can tell me WHY? Never can learn enough about FI IMO... LOL THANKS
Old Mar 22, 2007 | 06:29 PM
GT35R is a larger turbo then the GT30 is. Sure its the "same" pressure but the gt35r is moving much more air at that pressure level then the gt30r.
Old Mar 22, 2007 | 06:30 PM
2QYK4U's Avatar
Pardon me for not knowing the specific terminology, but I believe it all has to do with the larger compressor wheel and being able to pull more air through. If you were to compare a dyno with a GT3071R @ 19psi and a GT35R @ 15psi, both may make the same peak horsepower but you can bet the mid-range power curve for the GT3071R will be much better. One of the benefits of the smaller turbo is its ability to spool faster.
