How much hp per lb of boost?
Old May 7, 2006 | 05:49 PM
Nick32's Avatar
Default How much hp per lb of boost?
just wondering about how much hp gain each psi is equal to.
just trying to figure out how much i wanna boost up to achieve the numbers i want..
thanks for any help given
Nick
Old May 7, 2006 | 08:03 PM
Sideways's Avatar
It should be around 14- 15 hp per lb boost give or take a little. Take your baseline and subtract it from your known hp at low boost then divide that hp by that lower boost.
With headwork it may be higher and with a thick head gasket it may be a lower number.
Old May 7, 2006 | 08:53 PM
Nick32's Avatar
alright.. thanks alot
and whats the average ctsc on stock psi dyno at? just for an estimate
Old May 8, 2006 | 10:10 AM
s0rted's Avatar
Do a search, or look at the dyno sheets on the comptech website.
Old May 8, 2006 | 10:19 AM
slimjim8201's Avatar
HP/psi numbers are influenced mainly by the dynamics of the head. All stock S2000 motors should have almost identical HP/psi numbers. The reason a good turbo system has a higher number is because there is much less parasitic drag on the motor. A Comptech supercharged engine and a Lovefab turbocharged engine will both produce the same HP/psi numbers, but the Comptech will eat a certain amount of power in spinning the charger.
Old May 8, 2006 | 11:24 AM
Sideways's Avatar
Interesting point but so off topic.
That drag is about 70 hp at max impeller speed with the Vortech V2 SQ SC. I have not seen numbers published for the Comptech.
Old May 8, 2006 | 12:05 PM
Not off-topic at all. Just clarifying what HP/psi really means. Someone is bound to ask why a turbo produces a higher figure...and there is a reason for it.
swifbboy
Mar 13, 2015 11:32 AM
Peter@ISP
Jul 23, 2009 07:43 AM
jenniferbubalo
Jul 19, 2001 01:33 PM
