How much more power would a s/c s2k have to
Old Aug 4, 2009 | 08:51 AM
Riceboi's Avatar
Default How much more power would a s/c s2k have to
Turbo gives you more power early on, so turbo s2ks pull on s/c ones correct?
So two s2k's with the same whp, the turbo would pull, but how much more whp would a s/c s2k have to have to beat a turboed s2k?
I hope my question makes sense, just wondering about this.
Thanks
Old Aug 4, 2009 | 08:56 AM
JoeyBalls's Avatar
I dunno much, but it all depends on where the cars make power (size of turbo) and Torque...........
Old Aug 4, 2009 | 09:49 AM
DeadZero's Avatar
Theres a video on Youtube about this.
a turbo will always be faster........
the s/c has to build boost with rpm... at 6k you could be making 260hp but at 9k rpm be making 400.
The turbo'd hits max boost at like 4-5k rpm. at 6k rpm your making 320+ and 400hp on redline.
A turbo has a much better power curve then a supercharger. thats why when the 2 race each other the turbo'd car will pull much harder each shift.
The s/c shifts and loses most of its power and has to build up boost to redline again. The turbo shifts then guns it and is making max boost and yanking
Old Aug 4, 2009 | 09:55 AM
DeadZero's Avatar
[media]http://www.youtube.com/watch?v=J5z3rmOX1To [/media]
[media]http://www.youtube.com/watch?v=Q-csg6QsMrw [/media]
Old Aug 4, 2009 | 10:01 AM
S20004ME_PDX's Avatar
The answer seems pretty straight forward, unless I'm completely off base.
But building off what deadzero stated, basically, from a roll, the HP you make between 5-6K rpm needs to just as much as the turbo makes at peak HP. That's the only way you're going to have a chance to over take a turbo S.
Old Aug 4, 2009 | 10:09 AM
Snowmoto125's Avatar
I doubt that video was filmed in mexico lol.
Old Aug 4, 2009 | 10:35 AM
siadam's Avatar
It's pointless to take a video and say the cars were on 5psi...we need to KNOW how much power they were putting down.
Example.
Tuned on the same dyno, both making 300whp.
That would be a true test.
The s/c will come up on the pipe quicker, but the turbo car should have a stronger area under the curve...and most s/c cars only make peak power @ peak rpm, whereas a turbo car can make peak power much sooner.
Old Aug 4, 2009 | 12:04 PM
MugenRioS2k's Avatar
only applies to KW,CT and VT
roots supercharger is instant boost
Old Aug 4, 2009 | 12:21 PM
KewlWhip's Avatar
Yes but currently roots blowers cannot produce near the power of the high end turbo systems that are available.
-Chris
Old Aug 4, 2009 | 12:36 PM
I know some one that is looking to push the SOT setup to +370 may be even 400.
The pulley up grade should push him into 11 to 12psi range.
I don
