How often do you inspect your plugs?
Old Mar 23, 2007 | 05:21 PM
2QYK4U's Avatar
Thumbs up How often do you inspect your plugs?
I am curious to know how often you FI peeps check your plugs to determine the "health" of your engine (or tune)? I haven't checked mine since going FI, and plan on checking them at every oil change.
Old Mar 23, 2007 | 05:33 PM
SPECIAL-OPS-S2K's Avatar
good question I am curious as well...
Old Mar 23, 2007 | 05:41 PM
Spec_Ops2087's Avatar
I check and/or replace every oil change depending on condition
Old Mar 23, 2007 | 06:20 PM
afwfjustin's Avatar
^What type do you run? I have a set of NGK 9's going in...
Old Mar 23, 2007 | 06:21 PM
Kwando's Avatar
how many people reuse their NGK 7173 plugs? cleaning them lightly with sandpaper and just swap out plugs during each oil change.
Old Mar 23, 2007 | 06:22 PM
Enthralled's Avatar
at almost 30k miles i just replaced them with the NGK 7173.the existing ones were still good.bolted the charger in at 13k miles.
Old Mar 23, 2007 | 06:25 PM
2QYK4U's Avatar
What plugs are those? I have NGK 3330s (BCPR7ES), which I believe are 1 step colder.
Old Mar 23, 2007 | 06:32 PM
Enthralled's Avatar
[quote name='2QYK4U' date='Mar 23 2007, 06:25 PM'] What plugs are those?
Old Mar 23, 2007 | 06:33 PM
2QYK4U's Avatar
Originally Posted by ENTHRALLED' date='Mar 23 2007, 06:32 PM
the ones everyone uses..
Um, please be more specific. I did a lot of research prior to going boost and found a lot of people running the 3330s. I don't understand what model you are using.
Old Mar 23, 2007 | 06:35 PM
Enthralled's Avatar
https://www.s2ki.com/forums/index.php?showt...=fi+spark+plugs
