How to uninstall Vortech Supercharger to install pulley
Old Apr 5, 2014 | 12:31 PM
dannythewonder's Avatar
Default How to uninstall Vortech Supercharger to install pulley
Can someone show me how to uninstall the blower to install a new pulley. I want to install the new pulley by myself instead of taking to any shop to save money. Can anyone tell me what to do? If I can't find any info, I'm going to take it to a shop to have it done.
Old Apr 5, 2014 | 01:32 PM
APoner's Avatar
Un installing the blower is very easy. You should have the blower out and pulley swapped in a couple of hours. I dont have a vortech but if its anything like the SOS just losen the tension on the blower belt.Take off the oil feed and return. Unbolt blower. Swap pulley torque to spec and install everything in reverse order and torque to spec.
You dont have a copy of the instructions?
Old Apr 5, 2014 | 01:43 PM
Vi37573r's Avatar
http://www.vortechsuperchargers.com/images/46.pdf
Old Apr 5, 2014 | 03:22 PM
99SH's Avatar
Ive always had to use a gear puller to slide it off the shaft.
Old Apr 6, 2014 | 12:55 AM
The instruction that Vortech provide is kinda hard to look at. I was wondering if anyone here have a better DIY.
Thanks
Old Apr 6, 2014 | 12:56 AM
I believe my dad have a set. Thanks for the help. =)
Old Apr 7, 2014 | 08:07 AM
jdmdohcpower's Avatar
Not sure about vortech but with the Paxton blowers, you don't need to remove the blower. Hold the shaft bolt on the outlet pipe side with a wrench and crack the pulley bolt. Pull off the pulley and put new one on. Don't forget the little metal strip to hold it in place. May not help in your setup or maybe it will. That's how I've done it a few times.
Old Apr 7, 2014 | 10:22 AM
Moddiction's Avatar
Former Sponsor
You do need to remove the blower or at least pull it mostly off. The belt can't go on without pulling the blower and bracket partly off the car.
530s2k
Jul 13, 2011 01:29 PM
Skatethesea
Jan 11, 2009 04:35 PM
boszyen
Jul 13, 2008 10:09 PM
