I have two EMS systems -
Old Feb 18, 2007 | 09:02 AM
afwfjustin's Avatar
Default I have two EMS systems -
Hey guys, I had an InlnePRO kit and just sold that and am switching to a Lovefab setup. My kit had an EMS 1052U and was using 650cc injectors. My new kit is coming with a 1012 unit with Frog harness for relocation behind the seat and 1000cc injectors. I have an AEM serial gauge that I want to use regardless. I would rather sell the 1052U because I can get more money for it, however, if I use the 1012, will I still have all functionality with my serial gauge and fuel/oil pressure sensor? Will I have to then buy a UEGO gauge for the 1012 unit?
Which should I keep?
Thanks
Old Feb 18, 2007 | 11:05 AM
pushin9's Avatar
sell the 1012. Use the the 1052U with the 1000cc injectors. You would have to buy the uego to get all the gauges on your serial gauge to work with the 1012.
Old Feb 18, 2007 | 11:11 AM
gotswap's Avatar
Keep the 1052 newer better design has the WB02 already built in and it fits in the stock kick panel. Used price is only about $100 difference. You should be able to sell the 1012 for 800-900 depending on how patient you are.
Old Feb 18, 2007 | 11:23 AM
afwfjustin's Avatar
^thanks for the heads up guys - good info. The 1012 comes with a Frog harness for relocation under/behind the seat so that'll definitely be a plus when trying to sell
Old Feb 18, 2007 | 12:32 PM
JDM S2000's Avatar
Banned
1012 fits in the stock location also
But stick with the 1052
100 dollars is worth the peace of mind. Plus like the other guy said, built in WB02
Deception
Jun 22, 2009 09:30 AM
jdnissanz
Jan 3, 2007 05:56 AM
