id1000s. plug and play problems?
Cut the old ones off, solder the ID's to the harness, use some heat-shrink tubing and finish it off with oem style plastic wrinkle cable hose with lots of black tape around it..
You can also pull the harness under the intake manifold for that extra clean look!
Holy hell, I didn't know that ID had this issue... Well fawk. I've got to switch back to stock injectors when I get state inspections... does everyone have this issue with the PnP harnesses?
So you guys just basically took the PnP harness, snipped it in half, then snipped off the OEM plugs from the factory harness and soldered the ID plug where the OEM plug used to be?
Is this a connection issue like the problems with the OEM MAP sensor that led to the MAP whack TSB? Will putting a zip-tie around the PnP connectors help the situation?
I had my pnp for my I'd injector 1000 come loose in the past. When I ordered id2000 new pnp seem a lot better connection in pins don't seem so loose. Haven't had time to finish car so not sure if they work better, I may just wire direct before its a issue.
