ID1050X leaks
I'm having leaks through the injectors id1050x. I believe its maybe the o rings. But I was looking at how the id1000s were installed with stock cushions and an added washer. Just wondering if I need to that with the id1050x. It's also on a Aem fuel rail
So it needs no cushion or additional o ring from the oem injector? Ima swap out the top o ring that goes into fuel rail hopefully that stops leak. Thanks bro
If you are getting a leak at the top and the o-ring is completely seated in the rail you either have a bad o-ring or you have the rail/injector cocked.
Taking a second look. It looks like it's coming from bottom of injectors, on intake manifold. I tried tightening the nut on the fuel rail stud. But it keeps spinning and not tightening.
