DW1300 and DW300 on E85
Old Apr 3, 2016 | 07:10 PM
UH-60DRIVER's Avatar
Default DW1300 and DW300 on E85
I have a set of DW1300 injectors and a DW300 pump. After my engine build is finished what kind of power can I expect of of that duo on E85. Would it make a big difference if I upgraded to a walbro 450? I know there are a lot of factors but fuel will be my limiter for sure.
Sleeved and built engine
AEM V2
Borg Warner s360 twin scroll
Old Apr 3, 2016 | 07:56 PM
Chance S2K's Avatar
You'll need to upgrade your fuel lines as well.
Old Apr 4, 2016 | 02:02 AM
riceball777's Avatar
Why
The stock fuel line are good to over 700whp on e85. I make 620whp on straight e85 with just a walbro 450 pump and fic 1650cc injectors with stock fuel lines.
Old Apr 4, 2016 | 02:07 AM
AEM V2
1300cc injectors on stock fuel pressure will probably max out at about 550-600whp. That fuel pump will probably max out at about the same level. I would get the walbro 450 and turn the pressure up to 55-60psi at idel and you should get well over 600whp with the 1300cc injectors on e85.
Old Apr 4, 2016 | 04:48 AM
Chance S2K's Avatar
Originally Posted by riceball777
Why
That's just what I heard from my tuner when we were discussing flexfuel. Seems like that's wrong lol.
Old Apr 4, 2016 | 10:37 AM
Originally Posted by riceball777' timestamp='1459764142' post='23927336
[quote name='Chance S2K' timestamp='1459742209' post='23927224']
Why
[/quote]
06+ cars going for over 450whp need to upgrade to a return style fuel system because they have a returnless fuel system. This involves adding and changing the fuel lines. One of the main reason no one that goes for big power has an 06+s2000.
Old Apr 4, 2016 | 10:58 AM
Chance S2K's Avatar
Originally Posted by Chance S2K' timestamp='1459774126' post='23927420
[quote name='riceball777' timestamp='1459764142' post='23927336']
Why
[/quote]
[/quote]
Ohhh, that's pretty interesting. I didn't know that about the DBW models.
Further reinforcement that 04/05 are the best AP2's from the factory (arguably best S2000 factory).
staylor725
Dec 11, 2017 10:03 AM
riceball777
Sep 21, 2011 10:00 AM
Redline S2K
May 21, 2011 06:44 AM
JDMallmotorAP1
Mar 19, 2010 05:30 AM
NightStalker
Jan 11, 2006 04:50 PM
