ID2000 idle quality on E85? 12:1 AFR or more?
For those who are running ID2000s, what kind of air/fuel ratio are you able to get at idle and cruise (using E85)? I'm considering a set, but concerned that I'd give up idle and part-throttle crispness.
Love the crispness (15:1 idle and 15.5:1 cruise) that my ID1000s (and Walbro 400 LPH E85 pump) provide, but am at 98% duty by 7000 RPM, 16 PSI (GT3076R F22C) 11.5:1 on E85. Tried adding fuel pressure, but that didn't drop duty enough, and when I made it to 75 PSI rail base (FPR unhooked & plugged), the pressure seems to drop at the same time duty hits 98%.
If ID2000s wind up being too rich, I'm wondering if a second rail of ID 1000s would fit the bill (staged injection at onset of boost, rail mounted somewhat upstream of the original factory location/rail.
Thoughts welcomed.
Thoughts welcomed.
Thanks guys. Priority is avoiding 13:1 ratios and awful transitional pooling I had on my RC 1000s (which resulted in fuel wash and puffs of fuel sucked through the engine at 6000 RPM closed-throttle transitions during autocross).
But if the ID2000s will idle over 14:1 air/fuel ratio and cruise in the 14-15 range, I can live with that if simply wiring the 2000s in will fix my other issue (of running out of duty at 7000 RPM / 16 PSI / 11.5:1 AFR).
Welcome any other ideas too.
I have FIC 2150 on E85 with a base pressure of 55psi. The sweat spot seams to be around the low 13 at idle. I have to run a little richer at idle so that I don't get a lot of popping from the injectors. Now cruising is great. Also I am on Flashpro with dual 340's and 8an feed and return.
Thoughts welcomed.
Thoughts welcomed.
