Ideas on block
Old Feb 10, 2014 | 03:32 PM
Tecaterob's Avatar
Default Ideas on block
I just finished my turbo setup and want to build my block.
I currently have a stock 2.2.
3.5 kings turbo kit (with 6766)
8.8 diff
Stock trans (for now)
Fuel for 1000+
I'm at 752whp for now
Question
How much power does the 2.4 hold
Should I go with 2.2 or 2.4
Thanks guys
Old Feb 10, 2014 | 04:44 PM
S2-Kai's Avatar
I think if you go with the 2.4l, it will be a trade off of either thin cylinder walls (from boring) or less than ideal rod/ stroke ratio (from stroking). But since you don't seem shy about spending money on your car, I'm sure any one of the tuning shops on this forum will be able to put together a good bore and stroke combo for you to reach 1000whp, reliably.
Old Feb 10, 2014 | 05:05 PM
redboost10's Avatar
Talk to Saul at Mission Critical Performance. Very intelligent.
Old Feb 10, 2014 | 05:32 PM
d-bo's Avatar
i think the question is what does your power curve look like? if you're still making power way up top, which i assume you are.. i would believe the 2.4 will cut you short.. you will push things to the left a bit but i don't know if that trade off is worth not being able to rev as high (i assume you cannt rev as high)
Old Feb 10, 2014 | 05:40 PM
Tecaterob's Avatar
I read somewhere in the forum, a member built a 2.4 and still reved it to 9500. I'm looking for 1000+ and spray off the line.
Old Feb 11, 2014 | 02:40 AM
JJAUTOWERKS's Avatar
Former Sponsor
In all honestly, talk with Fernando over at Kings Performance.
Old Feb 11, 2014 | 04:58 AM
bobbyrandolph440's Avatar
8.8 diff
Fuel for 1000+
Question
Thanks guys
Kings will tell u like he told me a Benson sleeved f22 with there custom rod and piston set up on stock crank is all u need for 1000+ hp
Sent from my VS870 4G using Tapatalk 2
Old Feb 11, 2014 | 05:19 AM
wadzii's Avatar
Banned
What are the goals for the car? a 2.0, a 2.2 and a 2.4 all have their places, just depends on what you are doing w/the car.
For a pump gas street car you're going to drive a lot a 2.4 or 2.2 would be the best, if you are drag racing I'd stick w/the ap2 crank,
There is really no need for a custom rod, a good rod with a good bolt will hold 1000hp no problem. For pistons I'd use a full round skirt wiseco with a fat pin similar to what we run in the outlaw cars.
Also keep in mind that for over about 850-900 you will need to do the big stem exhaust valve upgrade and I usually recommend porting the head since you will loose some flow with the big valve stems.
Old Feb 11, 2014 | 07:58 AM
camuman's Avatar
so you are trying to run 8's? mid 8's?
Old Feb 11, 2014 | 08:03 AM
wadzii's Avatar
Banned
I wouldnt build a 2.4 for a drag car.. I'd build a standard size 2.2 liter and let it fly. I big crank will fly apart sooner than later. How often do you want to rebuild.
