Idle and drivability on pump gas with 2000cc injectors
I'm running the fid ev14 2200cc injectors. My tunner is Sean church. On e85 the car idles and drives great but on straight pump gas the idle is rough and the car bucks when I'm cruzing at low load at about 20 inhg of vacuum. So I went back to my tuner and he spent quite a while street tuner my car. The car idles on pump gas at about 12.0:1 air fuel and when in very light load cruzing the air fuel is around 11-12.0:1. The car now drives fine. When my tuner try's to lean it out the car would buck /injectors turning off. He said that the injectors pulse width is already set as low as possible during light load situations. Even though the car drive fine on pump gas now my tuner said long term with the air fuel being so rich is bad for my new engine. He suggest that I buy a smaller injector. I have no other options besides the new fic 1650cc injectors, as Id 1000cc and 1300cc injectors are too small and will max out on e85.
Does anybody have good idle and drivability results with 2000cc injectors on straight pump gas?
Has anyone tried the new fic Bosch 1650cc ev14 high impedance injectors? I ran a web search and there's quite a few high power supras and gtr's that have been switching to these new fic 1650cc injectors from 2000cc injectors because of the same issues I'm having. They seem to say drivability on pump gas is greatly improved over 2000cc injectors.
They're just too large on pump gas to get them to handle low loads as they are 2,200cc injectors.
ID is coming out with a 1,600cc+ injector soon, but you're on the right track with going to smaller injectors to regain low load accuracy.
FIC overrates those injectors, at best they flow ~1450cc or so. I am using the DW DV2 1500's and the drivability on them is superb.
For the 2200's, you need to run a very low base pressure and then they are manageable on pump gas, but still not recommended. I've used all brands of the 2200's and they really are a straight E85 injector. On pump gas you'll dip into the 1.0 ms PW region and it'll just rape you.
I agree that 2000cc injectors are really a e85 only injector.
I plan to run 91 octane 90% of the time but I still want to be able to pump in e85 and make 200 extra hp. Not too long ago there were only 2000cc injectors after the standard Id 1000 or id 1300cc injectors and those don't make much over 500whp on e85. That's why I'm asking about info about the new fic 1650cc and the deatschwerks 1500cc ev14 injectors.
DW actually gets their injector from a different division of Bosch. This was news to me when I asked, but apparently there are a couple different divisions of Bosch working on basically the same thing?
At what AFR? 11.5? lol. Fairy tales are for kids.
Originally Posted by riceball777' timestamp='1416785588' post='23415660
