Ignition upgrade for 800hp
Old Mar 22, 2018 | 04:58 AM
R-Poizon's Avatar
Default Ignition upgrade for 800hp
Hi.
I need to know what the best solution for make 800hp and not having spark blow out.
Are the rsx/tsx coils going to work at that power level?
Is Cdi box really needed for this power level?
The car will be for track / circuit
If I go cdi I will go for cbr coils and maybe a msd digital 6A.
What are you guys using?
Old Mar 22, 2018 | 06:49 AM
AP1Chief's Avatar
I run K series coils... work well.
Old Mar 22, 2018 | 04:51 PM
Spoolin's Avatar
I believe Kings uses the stock coils on over 1000 whp with e85. I'm going to do the same.
Old Mar 23, 2018 | 09:25 AM
Mijae007's Avatar
I've also heard k series coils work great on our cars. I've also read factory coils are good too as long as they're not already damaged (pins missing, etc).
Old Mar 23, 2018 | 04:01 PM
Spoolin's Avatar
I think mileage/use is the main factor on the stock coils. A brand new set or low mileage set will work well at high HP but not so much otherwise.
Old Mar 23, 2018 | 05:14 PM
AP1Chief's Avatar
Once I do my motor build ill be getting brand new OEM K series coils for mine
I have 90k K series coils on now, and i can run a larger gap with these, and seem to run better under boost.
Old Mar 23, 2018 | 05:45 PM
Mijae007's Avatar
Originally Posted by AP1Chief
...and i can run a larger gap with these, and seem to run better under boost.
Dude is this the secret to running a larger gap? This might help a lot ppl to idle better too
Old Mar 24, 2018 | 04:12 AM
AP1Chief's Avatar
Works for me
Old Mar 30, 2018 | 10:03 PM
R-Poizon's Avatar
Thats perfect
Really a oem solution.
Really didn't want to attach an msd box because is another thing to fail. So about the k20 coils, what is the model or part number!? Is the ones for tsx or rsx??
Old Apr 1, 2018 | 01:51 PM
Charper732's Avatar
Don't a lot of guys use kenne bell boost a spark?
