I'm getting my engine built @ Inline PRO
Much cheaper route is the OEM stroker kit. k24 crank, h22 pistons.
Or just use the k24 crank, k1 technology rods (specifically designed for the oem stroker kit) comes with forged rods already and are machined to fit the k24 crank.
and mahle gold series 87mm pistons. Throw a turbo and youll make a shit tons of tq. I just made 254tq on 9psi on 91.
Imagine 15+psi and e85.
Crank-$700
rods (oem)-$150
pistons (oem)-$54
Check it out
OEM stroker kit-Click here
Crank-$700
rods (oem)-$150
pistons (oem)-$54
Check it out
Crank-$700
rods (oem)-$150
pistons (oem)-$54
Check it out
Crank-$700
rods (oem)-$150
pistons (oem)-$54
Check it out
I know Inline sells rods now for the K24 crank but they are 700 or so for a set.
There website doesnt show prices. Its a swedish company. So contacting them is probably the best way to get a price. But the k1 rods are specifically designed for the OEM stroker kit that Design Craft made. k24 rods arent used in the oem stroker kit
Originally Posted by Soul Coughing,Nov 1 2010, 03:37 PM
Mike, glad to hear you're going to keep the S! You'll have to keep me posted on what you end up doing and how it turns out!
x2 glad to hear mike keep us update
Hi guys!
I just pulled the dyno sheets from the last 2.4 setup we did to give you an idea of how well it performs.
16PSI on 93 pump
InlinePRO Stage 2 race kit.
BW366
900cc injectors
AEM Version 2
Vehicle Speed:
Engine Speed:
If you have any questions please PM me.
P.S.
I cant wait to see how your setup does Michael!
16PSI on 93 pump
BW366
900cc injectors
AEM Version 2
Vehicle Speed:
Engine Speed:
P.S.
Thanks everyone for your thoughts and suggestions, I went to inlinePRO yesterday and dropped off my engine. I got a chance to meet Tom and some of the other guys that work there. I wanted to meet Jeremy but It took me longer to get there then I thought it would. So Jeremy had already left for the day. Anyway got a nice tour of the shop and got to watch the shop in action. They had a car on the dyno pretty nice integra and it was making over 400hp! I also saw a couple of S2000's on the lifts getting turbo kits installed not to mention some fabrication work being done. It pretty cool like the first thing you see when you walk in the shop is like 100 trophies 3 feet tall sitting on the counter
Anyway I talked with Tom again and decided to go with there F24 package which uses the OEM FRP Cylinders and replaces all the internal components of the engine including a custom stroker crank. My only concern is that my one cylinder is scored I think its pretty bad score but Tom didn't seem to worried about it. Jeremy will have to look at it and see if the block I have can be bored and honed to accept the internal components.
So I'm waiting to hear from inlinePRO if we can use my block, I hope so because after talking with inlinePRO and Jeff Evans I feel like this is best of both worlds when it comes to building an engine. You get the better internals and still retain the stock cylinders
Plus with the stroker option it should help my turbo spool better and thus making good Hp and Tq at a lower Psi.
Thanks Tom for posting up the dyno sheet I was going to post up the numbers from that setup we talked about for everyone to see but the dyno sheets are better.
