i'm hungry for more power
Old Jul 28, 2009 | 08:17 PM
s2guru's Avatar
dsddcd: laskey racing build block so 9:1, how can i tell if the intercooler is flowing perfectly? i don't think i have any leaks.
i have the Precision GT35R
Mase stooped at 17 psi, because i was having boost creep after that and he could nor control the boost.
TRBOKEV: i was on dyno dynamics
Why change the turbo, i seen people running 500+ with this turbo.
dsddcd: how can i pull a EGT log, i have a EGT sensor hook up to the ECU.
Old Jul 28, 2009 | 08:23 PM
camuman's Avatar
well, in most cases, you can add 10% or more to that nmber. dyno dynamics, when in a non corrected mode, can read 10%+ low. not sure if that helps.
underpressure made 550 on a land and sea dyno, i ahev no idea how that compares, but his was done at 18psi. so possibly, that manifold does have problems beyond that boost level.
honestly, i would swap for EL mani, 6262 turbola and bigger injectors. then a nice 500ish pump, and 650-700 e85
that should keep u busy
Old Jul 28, 2009 | 08:29 PM
dsddcd's Avatar
I know you probably know this but a GT35R comes in lots of different flavors. Presision on the other hand uses the Garrett center section but changes a lot of other things.
Since the car was creeping it sounds like you need to work out that issue. Did Mase make any sugestions such as a differnt wastegate, dump tube.......... If you can solve that issue you will probably make great power.
If the intercooler wahad problems you would see a large differential pressure accros the core but that is not real likley. The IC piping is a more likely source of issues but I would not worry about that either.
What are you using for a WG and dump tube?
Old Jul 28, 2009 | 08:35 PM
s2guru's Avatar
TiAL 44mm Wastegate, and the dump tube is open.
Mase told me is was more a manifold issues, the way the mani was design,
Old Jul 28, 2009 | 08:51 PM
PsykotiK's Avatar
u answered ur question.. get anew manifold.. full-race or mase manifold.. bigger wastegate should also help u
Old Jul 28, 2009 | 08:55 PM
s2guru's Avatar
i seen more guys with the same mani pulling 480+ ( same turbo too )
Looks like the solution is a new mani.
that means mani, down pipe, re route IC piping, coolant lines, ETC
Old Jul 29, 2009 | 09:55 AM
passmans2kny's Avatar
get urself a nice equal legth mani, i bet u pick up 50 hp with out changing anyhthing else
Old Jul 29, 2009 | 09:58 AM
AndyFloyd's Avatar
Originally Posted by BlitZs2000,Jul 28 2009, 06:39 PM
More boost or a bigger turbo.
a bigger turbo? Really....cause this one is rated at 650.
Old Jul 29, 2009 | 10:01 AM
AndyFloyd's Avatar
There was a guy locally with that same manifold and a Garrett GT35R that made just over 600whp. I think he was up around 28-30psi and had race gas to get those numbers. Lovefab mini-me is an overpriced piece of crap honestly.
Edit : Just checked that manifold is 1200 new. I got a pfab ELTM for 1000 and its far better than that mini-me. Sell the lovefab stuff and get something like full-race or pfab and I bet youll pull really good numbers. Hell lovefab's BUDGET s2k turbo kit is 7000...lol I dont know what kind of budget that is.
Old Jul 29, 2009 | 10:33 AM
DeadZero's Avatar
since mase tuned it, we can't accuse the problem is tuning hahahah. Get a Full-Race manifold and you will make 80+ hp.
Mase tunes his cars on the same dyno my tuner uses. and im making over 500 with that same turbo AND i don't even have a 3 inch exhaust.
