Increased boost, made less peak HP
Old Aug 9, 2012 | 08:52 PM
s2knoob89's Avatar
Originally Posted by 99SH
OK, I just bought the MAC controller and will give it a try.
I think you may have to send your flashpro to hondata to be modified for boost control..... I'm not sure.
Old Aug 9, 2012 | 09:11 PM
99SH's Avatar
It already has that feature. Just need to add a Pin to the ECU.
Thanks for the tip, I really hope it's this simple!
Old Aug 10, 2012 | 01:49 AM
Manny2587's Avatar
You need to send your ecu to hondata to add a pulse width output to pin b16.
Old Aug 10, 2012 | 03:09 AM
BuggyofMildDiscomfort's Avatar
What are the IAT's like? The extra heat isn't becoming an issue up top is it?
Old Aug 10, 2012 | 03:24 AM
RAIN H8R's Avatar
I agree with buggy. Take a look at your intake air temperatures. Post of chart of that if you have it. Post up your datalog while doing these to pulls...
Old Aug 10, 2012 | 04:12 AM
donaldmejr's Avatar
Originally Posted by donaldmejr' timestamp='1344566445' post='21926142
My guess would be that you proved a few peoples thoughts that if you limited boost with a Supercharger then you would lose to much CFM's and in turn make less power.
I hope this is not the case, but very well may be the truth.
Another thought which I think is exonerated is TQ drop due to over-spinning the blower. Based on impeller math, we overspin the blower around 7400RPM. I would think that the blower should be making enough CFM up to this point (although it would be on the edge of the compressor maps)
That us not that case as I am overspinning the blower with the same size pulley I felt a big jump in power.
Sent from my HTC PH39100 using Tapatalk 2
Old Aug 10, 2012 | 05:22 AM
camuman's Avatar
remember this, as boost drops, you hit different parts of the tune. ie rpm and boost = timing and fuel to run. as boost is diving up top your falling into different parts of the map, no doubt untuned or poorly tuned, which explains why you cant maintain at least your previous power at peak rpm and that boost.
get that boost falling problem fixed then get retuned, i bet power will climb and then flatten off, which is what should happen.
Old Aug 10, 2012 | 06:35 AM
spectacle's Avatar
From looking at the graphs you posted (good job btw), I disagree with what a lot of people are saying. Even though power and psi did fall off up top, you were still making more boost than previous so it should have made more power. You're on to something with the AFR going rich though. It might be worth disconnecting your exhaust and putting it back on the dyno to see if the power comes back...that would tell you if the Berk is truly a restriction on the exhaust side.
Old Aug 10, 2012 | 07:08 AM
99SH's Avatar
IAT's are good. I don't have any datalogs, but we did verify this on the dyno. FYI, the engine never heat soaked. There were so many fans blowing on it and at the aftercooler that you could place your hand on any part of the engine and still be cool.
Both plots are post retuning with the new pulley. Nothing here is untuned.
I agree with you, and this is the part that baffles me. I'm making more boost everywhere and should be making more power as well.
Old Aug 10, 2012 | 07:30 AM
camuman's Avatar
I disagree but I haven't seen your tune.
