Info needed from anyone with a sidewinder
Old Jul 29, 2013 | 08:13 AM
That Guy 1987's Avatar
Default Info needed from anyone with a sidewinder
I bought a kit and the only way to make this kit work is by removing the cross member which I'm not willing to do. Thinking long term I know this will hurt the resale of this car which will but a dent in my pockets. Now the questions for all you guys is are there any sidewinders on the market that I don't have to hack up my car to make the kit work. Previous owner is saying regardless of what sidewinder I use I'm going to have cut away at the cross member to some extreme.
Elliott
Old Jul 29, 2013 | 08:22 AM
Phill24's Avatar
Fbm side winder, full race, kings performance i believe u can just bolt on...i have the fbm mani..i grinded down a portion for the rail so i can run my wastegate lines under the turbo..thats not need but i did it anyways
Old Jul 29, 2013 | 08:26 AM
baZurk's Avatar
Just about any mainstream sidewinder will fit. Yours must be custom. You could replace the cross member with something that sits a little lower
Old Jul 29, 2013 | 08:29 AM
Phill24's Avatar
[attachment=43153:ImageUploadedByTapatalk1375115338 .260323.jpg]
Attached Thumbnails Info needed from anyone with a sidewinder-imageuploadedbytapatalk1375115338.260323.jpg
Old Jul 29, 2013 | 08:45 AM
That's the issue it is. Oil return for the turbo sits right maybe have an inch from the cross member.
Real question is how vital is that cross member and if god forbid I removed it could I weld it back in place if I ever decide to sell the car. I don't want to take away from the handling of the S neither.
Old Jul 29, 2013 | 08:50 AM
camuman's Avatar
i woudlnt remove it. but i dont have any reason other then its there, and looks important to me. a properly built sidewinder shouldnt need it removed anyways.
Old Jul 29, 2013 | 10:18 AM
illestrolla's Avatar
Also another sidewinder owner here. Diddnt have to touch mine either, My CHRA sits infront of it, and my exhaust housing is nestled right above the Xmember.
you can always have it cut out, and weld in a tube to replace it.
Someone did that recently if you want pics, yellow car, used to have the AFI kit..... help me out guys, drawing a blank on who's car it is.
Old Jul 29, 2013 | 10:22 AM
baZurk's Avatar
https://www.s2ki.com/s2000/topic/905.../page__st__650
Old Jul 29, 2013 | 10:50 AM
siadam's Avatar
Removing the cross member was the best thing I did in terms of actually working on the car.
I used a tube from a mustang sub frame connector, cut it to fit, welded in 4x4 plate, and then welding it in between.
Running oil drains, piping/etc is a million times easier.
I'd recommend doing it, looks way cleaner imo anyway.
Old Jul 29, 2013 | 10:52 AM
camuman's Avatar
pics or it didnt happen.................
