Info needed from anyone with a sidewinder
Looking very seriously at a sheepy kit but any clue if mods will have to be made to the cross member to make it fit?
I have the KP v2. My turbo sits a little far forward so I had to run my oil return over top and in front of my cross member but no cutting was required. If you're worried about losing money in the long run.. Save it and buy a quality sidewinder now. Just my .02
It's pretty much a complete lost. The manifold has the turbos oil return to close to the cross member, the IC piping only fits if I take it out, and just sent the turbo out because the cold side of it had quite a bit of oil in it and the cold side piping.
Their are pics posted above. I mean this isn't rocket science, you cut the old one out, and weld something smaller in place. You'll find the oem crossmember is a box channel, a round tube imo makes the car stiffer as long as you weld in some plates to distribute the forces across the frame.
My car was on jackstands when I cut it all out, and then I lowered it on the ground before I welded anything back in, to make sure the car was flat/level and not twisted on the stands.
