Injector Fitment?
My friend has a tubro integra GSR, but he bought two sets of injectors and now that I am turbo I was wondernig if I could use his second set of 550CC I know size wise they are correct, but will the injectors direct bolt-on to the S2000?
It depends what kind of injectors they are. All the RC's i've seen are too tall to be a direct swap. You need to use spacers under the fuel rail studs to hold them at the correct height.
For the wiring to be almost a plug in, they need to be high impedence injectors. The stock injector connectors will have to be replaced to plug into the new ones.
Low impedence injectors will require a resistor box, or the EMS peak/hold injector driver.
All larger than stock injectors will require some type of engine management to control them. (EMS, E-Manage)
