Injector type and size
Old Jun 15, 2006 | 11:12 AM
geists2k's Avatar
Default Injector type and size
I have read the FAQ and looked around quite a bit and I can't find exactly what I'm looking for. If the search worked I might have found it
Anyway, I have a question about injector type and size.
I will be installing a Vortech kit soon on my 2004 AP2. This kit ships from Vortech with a 4.5 inch pulley and this chart indicates that would make ~8.5 pounds of boost at the redline:
https://www.s2ki.com/forums/index.php?showt...0&#entry5886738
This being the case, I would imagine that simply cranking up the fuel pressure with the stock injectors might make things a little too lean at high RPM.
So, what would injector size would anyone recommend? 440, 550?
I also have a question on the type of injectors that everyone is using.
Peak and Hold or Saturated High Impedance?
I don't know the difference. Any help is appreciated.
Old Jun 15, 2006 | 11:59 AM
geists2k's Avatar
I did note this in the Vortech install manual:
SUPPLEMENTARY FUEL INJECTOR INSTALLATION (2004, 2005 MODELS ONLY)
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
I wonder if it still might be better to skip this and their black box, add an EManage/EMS and injectors.
Thoughts Sideways, XViper...
Old Jun 15, 2006 | 12:33 PM
John_Z's Avatar
You will need an Emanage or EMS to run larger injectors with 550's being the max the Emanage can support(but don't hold me to that). If you plan to run more boost in the future, it would be a wise investment to go EMS with 750 injectors so you have room to grow.
Old Jun 15, 2006 | 01:06 PM
geists2k's Avatar
[QUOTE=John_Z,Jun 15 2006, 03:33 PM] You will need an Emanage or EMS to run larger injectors with 550's being the max the Emanage can support(but don't hold me to that).
Old Jun 15, 2006 | 06:00 PM
kane.s2k's Avatar
550cc injectors, remove the rising rate fuel pressure, add AEM EMS
I don't recommend the E-manage quite frankly and the ultimate is pretty uncharted.
Old Jun 16, 2006 | 02:55 PM
AusS2000's Avatar
I just happen to have some 550s for sale. They were used with a Comptech SC, 8psi and an E-manage.
Rdragon
Dec 1, 2010 12:28 AM
Kinnersly
Feb 22, 2010 01:36 PM
gearhead313
Jun 17, 2008 05:46 AM
GaryRudolph
Feb 27, 2008 12:04 PM
mayhan1980
Nov 17, 2003 09:45 PM
