injectors 10 lbs boost
Old Aug 6, 2007 | 07:14 PM
kylemonster85's Avatar
Default injectors 10 lbs boost
i just bought an emanage system and i currently have the money for 10lbs boost pulley and injectors but i was just wondering wut is the best size for this comptech sc/ac setup thanks
Old Aug 6, 2007 | 07:22 PM
Spec_Ops2087's Avatar
675cc, works fine with the emanage and can run 10psi no problem.
abv's Avatar
abv
650cc are fine till around low to mid 400hp...you can go 750cc if you plan on going to high 400hp and up. If I were to guess I'de say you'll be in the 350-370 hp range..
Old Aug 6, 2007 | 07:29 PM
gerdaland's Avatar
i got rc 750 for you too..
Old Aug 6, 2007 | 07:34 PM
ChefJ's Avatar
550's would be lpenty for any supercharger that is only at 10psi. Anything larger would be overkill.
Goodluck with the emanage.
Old Aug 6, 2007 | 08:18 PM
EriS2k's Avatar
I'm Running 550's with 12psi!
But get 650's just to be sure!
Old Aug 6, 2007 | 10:51 PM
thanks and do i need to purchase new clips also
Old Aug 7, 2007 | 02:45 PM
duff0000's Avatar
Wouldent 650cc be better off for people who live in colder climates? The injectors wouldent be at 80-90% duty cycle all the time.
Thoughts?
Old Aug 7, 2007 | 03:54 PM
John_Z's Avatar
Get 750's. They will offer room to grow.
Old Aug 7, 2007 | 03:58 PM
dragtek's Avatar
u will always want more power so u will need the bigger injectors
